New blade for Spokeshave
Alf
22 Oct 2003
Up the proverbial creek
SDP,
If it's a friction fit type like that you may have trouble, especially depending on the required size. I'm pretty sure Bristol Design make new ones, but in only one size as I recall. No website but there's a contact email address here or phone 0117 929 1740. Alternatively you might be able to fit it with a adjustable type Hock blade perhaps? Other than that it's just a case of ringing round the dealers and hoping for the best (found these, but five?!). In all likelihood it'll probably work out cheaper to get another shave I'm afraid. :( What's the trouble with the existing one? Worn out?
Cheers, Alf
Argus
21 Oct 2002
Those old Spokeshaves were excellent and I have bought and used many of them over the years. The only problem with the ones you buy second hands is that they tend to be worn out – either the wood or the blade, though sometimes you find a good one. Some of the smaller one are beautifully made from box and are a joy to use.
The problem with many old shaves of this type is that the blade dimensions were never really standardised, so it is difficult to match a blade from one tool to the yoke of another. So it is sometimes necessary to make a new yoke matched to a particularly good old blade. The old article from the Woodworker is a good description of how to make one.
Bristol Design does supply some blades but they are big and rather clumpy and making the Spokeshave yoke itself is a fiddle.
If you are a chair maker, Bristol Design used to do a range of Travisher blades in 6 sweeps and these are worth getting because they are almost impossible to obtain other wise.
The main advantage for this type of shave is the ease with which they can be adjusted once you are practised in their use and the fact that you can keep two settings on the same tool by opening the throat aperture wider at one end to provide a more aggressive cut, finishing with the finer end.
In comparison to the metal type it is a different tool altogether because the angle of cut is much lower, almost horizontal. Allowing for the back bevel and a slight angle of attack below the face of the blade, your compound cutting angle can be as low as 10 degrees. This means that you can cut end grains and grain on contours that are presented at an angle without the risk of tear out or chatter with a superior finish.
Hope this helps – I love old tools because of the simplicity of many of them and in many case they will provide the finish I prefer – straight from the blade.
Scrit
17 Sep 2002
SDP
Apart from Charles S at Bristol Design the other possibility is Ray Iles. He already makes a number of replacement irons for bench planes and has been known to forge one-offs, too. Ron Hock at Hock Tools in Fort Bragg, California also makes replacement irons, but only in two sizes. As a last resort it might always be possible to obtain a piece of tool steel, W1 or O1 and have it forged onto the existing tangs and blade back - although you'd either need to find someone like Ray or a local traditional blacksmith (i.e. not a wrought iron gate maker, but someone with forge facilities) to do the job for you.
Good luck
Scrit
llangatwgnedd
17 Sep 2002
Castell Nedd, De Cymru
Thanks all and sorry for being late in replying probally due to the time of year.
Lots of ideas in your replys I might go they Ray Illes route to solve my problem.
The seconed wooden shave I have is a small wooden on made by Whales it only requires resharpen feels lovely in your hands compared to my Record iron shave.
Once again thanks
BTW, Alf I thing some one was trying to smooth the tops of nails with the larger shave, it now has teeth like that shark in "Saving Nemo"
