Woodythepecker
- Joined
- 30 Jul 2004
- Messages
- 686
- Reaction score
- 0
My cheap old moisture meter has given up the ghost and so i need to get a new one.
The trouble is after doing a lot of research i am still no nearer as to which type i should get..
First of all we have pin or pin less. I have read that the pin type is more accurate, but if this comes down to 1/2 or 1% does this really matter?
A plus for the pin less, is that they are said to be better/faster for scanning a length of board, is this correct?
I have also read that the pin less is non intrusive. I can understand that this would be a problem with antique or fine furniture, but is it really a problem if you are just checking wood in a timber merchant? Or am i overlooking something else?
One point i am not to sure of is surface moisture, how does the non pin type know which is which?
What about calibrating for different types of timber, is it easier to do this on one type or the other?
What models do other members have?
Many thanks
Woody
Many thanks
Woody
