Blister
Please post and questions / comments here
nev":2ild4yhu said:last month engineering , this month baking! :wink:
must the tazza be made from three pieces? no combined foot/ stem combo or similar?
and must the cake be edible? :twisted:
jumps":34ufk5jl said:Can we glue bits together before turning them? For example a couple of pieces to create sufficient thickness to turn the upright from? Taking this a little further, can we inlay contrasting woods rather than paint, stain or burn the poor thing![]()
boysie39":207nytlp said:Can Wheaten or Brown bread be used instead of a cake because that is what the cookery class in my area is doing this month. :roll:Will hold off booking in 'till I get an answer
.Will have to buy an apron as well and a white hat. Might be as well if you said No.
Blister":1ju02c0n said:jumps":1ju02c0n said:Can we glue bits together before turning them? For example a couple of pieces to create sufficient thickness to turn the upright from? Taking this a little further, can we inlay contrasting woods rather than paint, stain or burn the poor thing![]()
If we allow multiple pieces of wood to be used it could continue on to the top and the base and we could end up with segmented work with 50 or 60 pieces
It then becomes more of a carpentry challenge involving planers . thicknessers , chop saws etc
so as it is a turning challenge the base stem and top need to be from one piece of wood each item
Yes if you want to include inlay as decoration you can :wink:
gregmcateer":1lt83mek said:How many layers does the cake have to be? :lol:
Hudson Carpentry":3lfv0ped said:I have an issue. My lathe only takes upto 6" blanks and unless I have a flat top (no sides) I would need a 5" cake and as these are not really available the stand will not be fit for purpose. Well a 6" cake stand isn't really a cake stand, its a cup cake stand.
Wood spoiler":1m23jmiq said:Hudson Carpentry":1m23jmiq said:I have an issue. My lathe only takes upto 6" blanks and unless I have a flat top (no sides) I would need a 5" cake and as these are not really available the stand will not be fit for purpose. Well a 6" cake stand isn't really a cake stand, its a cup cake stand.
One word. Proportionality
Have you ever looked at dolls house models? Perfect in every way except one twelfth the scale.
If all proportions are right - including the cake - which then can be a cup cake no-one will be none the wiser. We have a cake tin which is 6" so if you can do a 6" blank you're sorted.
I am sure you will be able to sort it.
Blister":3s6145et said:Nev
The design is up to you
Paul did say this in his PM to me re the criteria
" Perhaps it's worth emphasising the cake stand part as some tazzas I've seen were effectively an elevated fruit bowl - which wouldn't be practical for use as a cake stand "
:wink:
Register today and take advantage of membership benefits.
