mahogany.....
thomaskennedy
8 Mar 2004
Huddersfield, West Yorkshire
well, i went to get some reclaimed mahogany a couple of weeks ago (they came from a leather tanning place :?: ) i only bought 3 pieces cos they were really heavy
2 at 2 3/4" x 8" x 9ft
1 at 2 3/4" x 4" x 10ft
as you would expect my little b&q chop saw didn't take either boards :p so i cut them in to "managable" pieces with a circular saw!
then i resawed the 4" wide boards on the T/S :? .....i had to pass it through twice :? 'twas quite scary! but i did it in the end...looks v nice but i now have to wait around 4 weeks 'till i get my P/T :(
never mind!
while im here im gonna ask a qustion (yet again :p )
i'm gonna buy some veneered boards but im scared that my T/S will tear the veneer? will it? im not sure but on NYW it doesnt but on Cutting Edge they use a scoring blade on their T/S ??
Tom
Dewy
11 Jan 2004
Gloucester
I think you'll find that good old Norm uses a blade that scores the veneer before the main teeth of the blade. He has often said about using speciality blades for cutting veneers or melamine coated chipboard.
Another way, if you have the finished size, is to score the veneer with a utility knife (Stanley knife) accurately before sawing. This prevents the breakout.
A
Anonymous
Guest
Hi Thomas
Nice buy :D
I too was concerned about this
I have a 'triple cut' blade. Every third tooth is ground to a thin cutting edge in the centre of the blade and the tip of these teeth is slightly higher than the other 'normal' offset teeth. Blade is 8" with 60 teeth!!
It is designed to cut vereered boards on saws without a scoring blade
Works very nicely when cutting Ash veneered MDF.
I got my blade from Oswald cox in Leicester 01162517378 and they can resharpen and retension it for you when the need arrises
Tony
Philly
24 Nov 2003
Dorset, England.
Thomas,
One trick to try is to lower the blade so only 3mm or so is showing, run the venneered board over, raise the blade high enough to cut the board, flip the board end for end so the cut side is up and run it through. This in effect is like having a scoring blade on your table saw. I've tried it and it does work ( though it is more work :shock: ).
Of course, this will only work if the riving knife on your saw is level or lower than the top of the saw blade. And you will have to remove the guard-so extreme caution is required :!:
hope this is of help,
Philly
johnelliott
16 Apr 2003
Near Swindon, Wiltshire
Another tip to add to the others above, is to apply some masking tape firmly to the underside of the cut
ps had a look at your website, that side table is too cheap, much too cheap
thomaskennedy
8 Mar 2004
:oops: im just scared of people thinking..."wwoohhh thats waayyy too expensive!" i might add a bit on :p i got everything for that table for around £50! so i suppose £15 isnt much profit :p
Tom
ps. the masking idea seems the easiest so im probs. gonna do that! tanks john!
thomaskennedy
8 Mar 2004
as promised :p i did it whilst in a boring lesson hence the lined paper :p :p naughty me!
btw i got top of the class in my resistant materials (technology) exam!! WOOO go me :p :p
the little lines to the left are for dvd's and t.v goes ontop, dvd player etc go on the three shelves! i thinked up this all by my self :eek:
johnelliott
16 Apr 2003
For a table like that in hardwood, think £200. Cost your time at say £15 an hour and the price will seem reasonable. People are not offered quality hardwood items, and have no reference to judge to value by, other than the price. Ask more and they will realise that it is worth more. They may not buy it, but they will realise that it is something of value
thomaskennedy
8 Mar 2004
well i got some beech from british hardwoods!very very nice people! and then i got some veneered beech boards...only manages to glue up the top and cut it to size today! looks like a long day tommorow!
Tom
