Machinery/ tool dilemma
craigs
5 Oct 2016
I wonder if you chaps could help my current issue.
After my bandsaw delivery, I find myself having a wee problem. I want a planer/thicknesser.... however with only a single car garage (admittedly quite a large one) I just don't have the room. Now im yet to experience all that my new bandsaw can offer however to make a planer/thicknesser fit...the table saw will have to go. now its only a bosch 10" which i made a little stand for.....but am i going to miss it? shall i just bung the current thicknesser and table saw in the for sale section and pull the trigger on an itech 260?
Craig
AJB Temple
Finely figured
13 Oct 2015
Tunbridge Wells
In my book a P/T is ten times more useful than a table saw. I do have a table saw but I have plenty of space in various buildings. 99% of the time I use the tracks or handsaw.
Spectric
19 Feb 2015
North Cumbria
Hi
You don't say what it is you are making or wish to do. You need to separate what you need from what you want and for me it has been wait until you cannot proceed due to needing for example a P/T. I had several items that were more important than a P/T, ie a good router table setup because I could buy PAR timber to get round the need for the P/T but could not get round the router. My tablesaw takes up to much space but for long rip cuts in 4 inch timber it is better than my bandsaw so it seems if space is tight we all face these issues. The ideal solution is more space, and make the machinery mobile so it can easily be moved when needed.
Doug B
Shy Tot
6 Aug 2008
@dougsworkshop
Put your machines on casters, this is what I do & have quite a lot of gear in a single garage but just move out each machine as I need to use it, also by lifting the bandsaw higher that the saw & planer as you cut timber on the bandsaw it passes over the other machines.
craigs
5 Oct 2016
Hi
So far mainly small boxes and tables in hardwoods which i now get from tylers (sawn), I have everything here on wheels to move around and it's all at the same height as my mft for infeed/outfeed if required. for sheet material I use a tracksaw,
craigs
5 Oct 2016
the bandsaw is at 960mm....everything else is it 900mm on castors (y);)
craigs
5 Oct 2016
its what im thinking, handy to remove bandsaw marks also
Trevanion
Greatest Of All Time
29 Jul 2018
Pembrokeshire
There was someone (Who I cannot remember, sadly) on here who said something along the lines "For every minute I spend on the table saw I probably spend an hour using the P/T" which is quite true.
craigs
5 Oct 2016
which means ?
powertools
7 Jun 2011
Bedfordshire
Craig
You say you already have a thicknesser so a planer thicknesser won.t take up much more room keep the table saw and buy the pl you will make it fit.
Trevanion
29 Jul 2018
Pembrokeshire
which means ?
Generally, you spend a lot more time prepping timber with planers than you do cutting it up with a circular saw. A saw is a nice thing to have but I could probably make do without one if I had to, I without a doubt wouldn't be able to survive without a P/T.
craigs
5 Oct 2016
that's my thinking
craigs
5 Oct 2016
i think the difference in size between a lunchbox type thicknesser and a cast iron planer/thicknesser is considerable in a small space. right now my thicknesser doesn't really have a spot to live and im a bit of a neat freak so it bugs me. I wonder how much I would even use the small table saw considering I now have a bandsaw, and I also have a track saw and router table.
powertools
7 Jun 2011
Bedfordshire
I all comes to the work you do I would keep the table saw get the pt and not bother with the bandsaw if space is that tight,
craigs
5 Oct 2016
I specifically got the bandsaw with the capability of resawing wide boards, it also takes a lot less room than a decent size table saw. as I said I only have the bosch GTS 10, but thats a significant enough space where a PT could live
sunnybob
wysiwyg
11 Oct 2014
cyprus
Make it fit.
I have a 3 x 5 metre workshop. I have a 350 bandsaw, a large (90cm square) router table, a mitre saw, a belt sander, and a table saw on casters all on one wall. I have a "lunchbox" thicknesser on top of a snap on type tool box on casters on the other side.
The bandsaw, router table and mitre saw are all set to the same height so i can run a 3 metre plank across any of them. The saw gets pulled into the middle of the floor when needed, as does the thicknesser.
The other wall has a 2.5 metre workbench.
It just needs a bit of planning.
Oddbod70
21 Aug 2020
Hampshire
I dont think i could do without either to be honest. I guess if I really really had to I’d lose the saw. But the bandsaw and everything else would go before those two!
Doug71
28 Aug 2016
Yorkshire
I could not be without my planer thicknesser but I have managed in the past without a table saw, just using a bandsaw and plunge saw instead.
