Andy wrote:
How i see it, it's double the price but you don't get twice the drill :?
Can't see the point in spending alot of money for something that drills holes but if your not worried about the price, then yes nice drills.
Yes, it is a lot more expensive then other drills, but then it is a lot more of drill.
These spec's are for the makita BHP451SFE 18V Litium-ion combi drill.
Remember that this is a combination drill and not just a drill/driver.
£299.00 (including VAT)
2 X 3.0AH Lithium-ion batteries
80 Nm of Torque
Weighs less than 2.2kg
45 minute charger
LTX Lithium-ion battery provides longer run time
Self-discharge (for use any time)
Metal 13mm chuck
Capacity. Steel 13mm
Wood 65mm
Masonry 16mm
Variable speed on trigger
3 speed gearbox
Two built-in LED lights for illuminating work.
No load RPM:
Low 0-300
Mid 0-600
high0-1,700
Blows/Min (BPM)
0-4,500
0-9,000
0-25,500
Battery and charger communicate though out the charging process using a built in chip in the battery and CPU in the charger.
45-minute charger has a built-in fan to cool the battery which extends its life.
3 speed design produces 25% faster working speed, which makes it more and more efficiency.
Charger uses "Active 3 Control" for current, thermal, and voltage control.
This drill is only 251mm in lenght, which will allow it to fit in tight spaces.
Andy, the real problem I find with Ni Cad and Ni MH is with the charging, eg memory effect etc,etc.
But with the Lithium-ion, you have no such problems. After you have finished with it, whether you have used 90% of the charge or just 20% you can sit it in the charger and it will fully charge it again, with no memory problems. In fact you can leave the battery in the charger and it will keep it 100% charged for a day, week , or year.
IMHO, this in itself makes a drill (any manufacturer) a big premium.
As for your line:
Andy wrote:
Can't see the point in spending a lot of money for something that drills holes, but if your not worried about the price, then yes nice drills.
I am not the only one who spends big bucks for a tool that drills holes, or in your case a saw that just cuts boards up.
Remember your little FESSTOOL TS55 saw? That too costs at least 50% more than another saw, which can cut lines equally as good.
Don't get me wrong I know that its a first class bit of equipment, because my dad has one. I was does showing you that we all at one time or another go over the top to get the best tool possible.
Anyway i am still waiting for some recommendations.
Mike
