Kity 619/1619 saw blades
seaco
17 Feb 2005
Somerset
Hi Steve
Did the mitre gauge arrive ok? also if you fit the 270mm blade I don't think the blade will lower completely into the table if I remember clearly just in case you use the saw as a part time bench as I do!... :lol:
Aragorn
6 Feb 2004
East Sussex
Yep that's right. With 270mm, you have a minimum cut height of 12mm.
I use my TS as an assembly bench too, so having a 270mm blade is a pain in the proverbial.
You get a max cut height of about 90mm with the 250mm blade, and I almost never cut timber bigger than this on the TS anyway.
Steve James
24 May 2003
Ellesmere Port, England
Thanks for the replies, Chaps!
Think I'll take your advice and stick with the 10" blade.
Seaco, Got the mitre fence last Saturday (or maybe the one before!!!!!)
Sent you a PM to say thanks, but you must`nt have got it or looked!
But, Thanks.
To say I`m pleased with the saw would be an understatement!
Don't ever let me have a go of a Unisaw, if it is really that much better!
Steve
Steve James
24 May 2003
Hi Seaco
Just had a look to see what date I sent you a PM.
And it seems I did`nt!!!
I must have done something wrong as I did write it, But.........
You can see why I make my living with wood and not PC's!
Steve
