Jet JWL1014VS-M weight limit
Gary Morris
10 Jan 2013
Birmingham
Hi, I was wondering if anyone knows if there is a limit to the weight of a piece of wood you can safely use on my lathe? I've looked in the manual and tried a search on here but can not find anything. Is it the common sense route - motor turns the piece fairly easily, clears the bed and fits between centres?
thanks
Gary
I doubt you can mount any piece of wood on the lathe that will fit between the normal fixings and tool rests that would be dense enough to be a weight it can't handle as far as mechanical strength is concerned, more significant would be the ability to balance the piece, either by trimming it or fixing weights to a face plate so that it does not cause significant off centre stress to the lathes components. Long heavy pieces obviously need care in ensuring end fixings are adequate.
I have been known to use a power planner to knock the corners off a piece until it was reasonably balanced before spinning it up.
    39.9 KB
Thanks guys, it felt real heavy, but once mounted turned (with my finger) quite easily. Thanks Phil, thanks CHJ
Gary
