January Challenge 2013
Status
Not open for further replies.
nev
21 Jan 2011
The green and wetter end of the M4.
The challenge is open to any and every registered UKW user. You must however sign up first (only need be done once) to get your name on the scoreboard.
An Acorn Box (click title for clues)
That is a lidded box in the shape of an acorn.
New work please.
any size.
any wood.
Texturing and or colouring acceptable on the 'lid'.
The box/lid can be either a push fit or threaded.
This months judge will be Paul Hannaby
Once you have completed your entry, please go to the scoreboard and mark your entry as ready. Then wait patiently til the end of the month (27th) when a new thread will be opened titled 'Post your entries here.' this thread will remain open for 2 days during which time you upload the required pics of your entry.
Please post 3 or 4 images of your work / entry as follows...
1 showing assembled box side view
1 showing inside the box and lid
1 showing side view of the "male" spigot / thread section
1 optional photo showing any other feature you think might be of interest
Image size please use image size 640 x 480 0.3 mp, same previous months
Please state wood type if known, dimensions and a little about how you made it and what tools and finish you used ( this helps the judge )
Entry’s to be uploaded from 10pm on 27th January up until 10pm on the 29th January.
After this time the thread will be locked for Judging
Results will be given on or before 31 January
Any entry's that are outside the rules and requirements will not be judged
The Judges decision is final ( Any negative comments re judging must be via PM only and not on the open forum )
NO Critique or comments on any work until February Please, After the Judging and results.
Any question regarding requirements or if any hints and tips are required please post in this thread.
Seeing as most of us are here to learn, please feel free to ask any questions related to this months challenge and maybe those more experienced can enlighten us and give us a clue.
Good Luck :mrgreen:
I'll start us off...
IF I dont have a chuck , whats the best way to go about making a box ?
can different woods be used?
does it have to stand up?
and is carving aloud ?
maybe turn one half as much as possible using a face plate, then still using the face plate make a jam chuck to finish it..... then do the same with the other side of the box.... checking it's a good tight fit on the first half turned?
hope that makes some sense :? im no expert !
Are there any restrictions regarding the dimensions of the box?
Also are laminations allowed?
With a bit of luck I will be entering a few this year :)
Melinda_dd":2el94l3v said:
1. can different woods be used?
2. does it have to stand up?
3. is carving allowed ?
1. yes
2. not necessarily
3. yes - but only on the lid (cap, cupule, the bit with the stalk sticking out of it!)
=Adam=":2el94l3v said:
1. Are there any restrictions regarding the dimensions of the box?
2. Also are laminations allowed?
1. no
2. I cant see any reason why not?
Nev,
Sorry to sound like a numpty, but doesn't the stalk stick out of the bottom of an acorn?
Greg
gregmcateer":1zhlqlkh said:
Nev,
Greg
only if you hold it upside down!
The cap and stalk can be textured/carved/coloured/abused but not the nut please. (This way there is at least a part of it that needs to be finished 'cleanly', no hiding of toolmarks etc :wink: )
MattF":kb35w07y said:
andersonec":kb35w07y said:
Tried to sign up but got the message "Sign up is currently unavailable"
Andy
I'm getting the same message as Andy
Matt
Sorry yes. scoreboard is being updated/ reprogrammed for the new year and not quite ready yet.
Will put a post up when its ready.
dont panic if you havent registered yet you've still got a few weeks :)
nev
q. I take it we can present either the nut or the capula as the lid of our box?
a. turn well over length, and a little over diameter, between centres and part off as appropriate, possibly finishing the last bit of the seperation of the lathe with a saw :D remount the pieces on screw chucks using the marked centres and take it from there - don't use too big a screw and you should be able to re-use the holes with your centres later in the process.
nev":1j5tosbn said:
jumps":1j5tosbn said:
I take it we can present either the nut or the capula as the lid of our box?.
woodyturner":1j5tosbn said:
Can we make it with the nut as the lid and the cup as the box ?
Yes, I dont see why not?
It's going to look a bit funny with the stalk coming out of the bottom of the box!!
Not if you mount it on something
no funnier that being balanced on that tiny spike in Nev's picture #-o
I would definitely like to have a go at this, tho i've never made a box before so may not make it to the finishing line. There's only one way to learn, .
Status
