It's hard to believe
Chippygeoff
19 Sep 2011
Nr. Swansea
The last couple of hours in the workshop have never been so frustrating. Earlier I had a dozen plaques that were customer orders and as usual I cut the outside first with a number 7 FD-UR blade, no problems at all, done it hundreds of times in the past. Then when it came to cut out the lettering or internal cuts I switched to a number 5 FD-UR and this is when things started to go wrong. I keep my blades in clear plastic test tubes and these are stored on a carousel by the saw. I had orded a new batch of blades from Mike's workshop about a couple on months back and these were up on one of the shelves. In the plastic tube I suppose I had maybe 10 blades left and I would use these up until the tube was empty and then put a gross of the new batch in.
As I started using the number 5 blades I started to lose tension after about 5 seconds of cutting. I had to keep stopping the saw, release the blade from the clamp, add more tension and then re-attach the blade, very time consuming when your in a rush. After about half an hour I had had enough. Some time ago I had the same sort of problem and what it boiled down to was that I was over oiling the bearings on my Hegner and this was seeping down to the tension rod. I have since cured this problem by obviously not oiling so often but as a safe guard I fitted thick hair bands to each arm so if oil did seep down the hair bands would absorb it. Today I did what I did before. I took the tension rod off the saw and and cleaned the threaded rod and both of the wedges. I cleaned under the arms as well and then put it all back together.
I started cutting again and exactly the same thing started happening again, I was losing tension. I knew in my heart there was no way it was oil on the tension rod, it was as clean as a whistle. Out of curiosity I put a new blade in, applied the tension, had a nice ping when I plucked the blade and then I put a white marker on the star knob on top of the tension rod, which was in the 5-O-clock position. I did some more cutting and when I started to lose tension again I looked at my marker and it was in exactly the same position and then I saw the light, the blades were stretching as they were cutting. I found it very hard to believe. In all my years of scrolling I have never seen this happen before. The problems I was having was struggling to keep the blade on the line, and then the wood started burring depsite the clear packaging tape on the wood and then the blade would not back up when I came to a tight turn. I took a new blade from the new batch and everything went like a dream. Problem solved. I can't wait to use up the new batch of FD blades and then I shall switch to a new supplier.
There were messages on here a little while ago with the CD blades from Mike, to short of I remember. It out me off and I don't think I will bother using them as I am getting on really well with Pegas blades.
Funnily enough Geoff I was watching a video on Youtube where the guy pointed out how sometimes the blades actually stretch and sure enough it was doing the same as yours has today, I also checked mine last week and i used a no7 and cut some 15mm oak with no problem..... following morning i plucked the blade and very dull sound and had to re-tension it before starting to cut again.
Regarding Pegas blades I bought some and they are excellent BUT I dropped them all on the floor and now haven't a clue what sizes they are doooooooooooooooooohhhh
After using The Nigua blades for several decades I decided to try some FD blades recently and as I reported here sometime ago I had a lot of problems with blades breaking and coming out of the holders, but everyone at the time raved about the FD blades so thought it must be just me!
maybe get in touch with Mike as he orders so many from the manufacturer to get onto the manufacture to find out why, if they do not know about the problem the problem cannot be solved and a lot of people who use the blades might think it's something too do with their machine.
I was working in a factory that used all materials to make aero engine, aero gearbox engines and racing car bearings and sounds like the metal is to soft, maybe over done it when annealing the material, they would not notice and it would be the user that loses out.
luckely with us was that so many operations and inspections would be done to it that if they were to soft or hard we would notice before it got to the customer but because Fd blades only cut the teeth after or before heat treatment they would not notice.
Tim
Contacting Mike would seem an obvoius, and useful, step.
BugBear
Very good post Geoff,Steve did say a while back that Mike (FD) has put posts on in the past.It is quite interesting that the adverse comments that have been made there has been no posts from Mike .
Bryan
I cannot complain about the service my blades arrived very quickly but I have received no reply to my email.
Mike did post quite a lot on here over the years, and it's not like him to not engage if something is not right .
Mike had some health issues over the years and may have someone covering for him if he is having treatment.
This is one reason why he may not be answering . I hope everything is alright with him as I found him very
helpful when I started off scrolling.
I will try and contact his company over the next few days and find out more .
If somebody else would like to take this on please do so as I can be involved in personal stuff for days or weeks
without any notice. Hope all is well with Mike and God Bless all .
I hope whoever contacts Mike at FD has better luck than I did --- it was surreal-- completely ignored my problem and told me my No 9 blade was perfect , even though I had sent a No 5 that was 5mm short and blunt as as a butter knife
A couple of years ago on a USA forum Mike did mention he had changed suppliers
His last post here was Feb 05, 2014.
BugBear
