pablopete80
- Joined
- 13 May 2009
- Messages
- 37
- Reaction score
- 0
Hi all
When i bought my house the single garage had been converted into a room and unfortuantly along time ago so is not insulated. I am now planning to insulate it and make it a bit more usable. I do however have a couple of questions i thought someone may be able to help me out with.
Its a centrally heated room (6.7m x 3.2m) with 2 D/g units and a D/g pvc door. 1 Internal door and a flat roof (ventilated bu no insulation). It only has a 1m party wall with the main house so all walls need doing.
What i have planned is to rip off all existing dot and dabbed plasterboard and chipboard ceiling. So when adding the insulated stuff it doesnt soak up the condensation.
Attach 40mm insulated plasterboard to the joists leaving the existing 100mm gap for ventilation and stopping short of the walls by 20mm to aid ventilation of them (the walls)
batten (50x25mm) the walls @600 centers.
Screw 40mm insulation to the battens.
Now the questions. As its not going to be a main living area just a games room i have not added a vapour barrier as its well ventilated and wanted any moisture to be able to escape out though the p/board and bricks if needed. Is this ok as i have read various advice on this?
Can i gripfil the battens to the walls instead of screws, allowing 24hrs to set before attaching p/board.
Do i leave a gap at the bottom of the walls to aid ventilation or is it enough at the top only?
Dont worry the floor is good so does not need sorting.
Oh and if its all completely wrong please advise on a suitable solution.
