I need the help of the very clever people that post in here
Dog
14 Nov 2003
Sleeping in a basket
....How do I make a simple profile sanding block so that I can easily smooth an edge which has been routed using a Classical Cove Cutter (1" x 1/2") ?
Thank you and may you all win the lottery tonight :D
Signal
23 Dec 2002
Joe,
1. take an ice cream tub
2. Line with cling film
3. Take a small section of your profile and wrap in clingfilm
4. Fill container with expanding foam
5. Push moulding into foam so its just below the surface
6. Cover with cling film but not to tight.
7. Leave to dry, can take a a couple of days :cry:
Carefully extract your moulding and trim it up.
Wrap sand paper round it pushing it into the contours Hey presto custom sanding pad in true blue peter style :lol:
Signal
Dog
14 Nov 2003
Great stuff, thank you Signal
Signal
23 Dec 2002
Ello Alf,
care to enlighten on your scraping method?
Im all confused, nothing new there eh :?
Signal
Alf
22 Oct 2003
Up the proverbial creek
Hey up, Sig,
Well, as always, it depends... :wink: Most of the time a suitable bit of old saw blade filed to a curve slightly faster than the curve I want to scrape is all I use. And an ordinary card scraper for the square bits of course. Occasionally, when time is tight, I have used the moulding cutter itself to scrape the moulding; even router cutters (this doesn't do the edge of your router cutters any favours though :( ). I have a feeling because of angles of cut and so forth this doesn't give you quite the correct result, but I'm not absolutely sure of the details of that. Not that I'm suggesting I don't use abrasives, 'cos I do :oops: but you can seem to get a much crisper finish from scraping than sanding, and it's not so messy. And anyway, while you wait for all that foamy stuff to dry you might as well scrape. :D
Cheers, Alf
Dewy
11 Jan 2004
Gloucester
You forgot the 'sticky back plastic' Signal.
When I was in school (many years ago) we were taught never to use sandpaper.
The plane should finish the piece off or you werent planing right.
I always made a beeline for the workbench that had a wooden smoothing plane.
They had a better feel than the new fangled metal ones.
Signal
23 Dec 2002
Dewy,
quite right, but have you ever tried planing a piece of coving or a dado rail :lol:
Signal
Dewy
11 Jan 2004
Gloucester
I don't get that involved. I keep well away from fancy shapes. Not that I dont use my random orbit sander on most pieces but table tops are too big for a plane iron :)
Drew
21 Mar 2003
North-East England
It depends on how much you have to scrape. As a glass user I have great success using small pieces of glass cut to shape. Its good for acute angles as well, a ready made scraping edge that can be renewed in seconds.
Drew
Dewy
11 Jan 2004
Gloucester
You mean that glass is used for something other than holding beer?
The wonders of modern science. :lol:
