Yes, I agree.
It depends completely on the job at hand.
A key point hasn't been discussed yet: rip fence position.
I sometimes work in a pro shop and people do it wrong all the time.
If you are ripping solid timber, the rip fence should be set to finish just beyond the point where the blade completes its cut: usually it's about the back of the gullet.
You're a brave man, Ian. Putting something like that up was sure to elicit either some nit-picking responses, or downright critical ones. You seem to have escaped without being too badly scathed so far, ha, ha.First off, this might not be 100% to the letter of the rules and I’m sure it will be pointed out to me! But it is a million miles better than the dangerous things you see on YouTube. Ian
Yes indeed, good point.Others sight the centre of the blade as the limit of the fence ie the point at which the rotation of the blade is changing from downward to upwards; between the gullet and the blade centre is ok.
All those cuts cut be made with just the left hand end of the board, in place of a sliding table, but a lot easier with a band saw!At the risk of setting you off on an argumentative tangent I'll answer.
Sometimes you need support on both sides of the blade for the project at hand especially when it isn't a through cut. I don't care to have the piece hanging out in space unsupported. Being able to fit stops, position blocks or other fixturing and clamping on either side can be useful when cutting multiples. If you only want to cut on one side of the blade just use a mitre gauge, either the original or an aftermarket. If you want a guard over the blade you can add the Lexan cover I linked to in post #9 that is fitted to the sled or have an overarm type that allows the sled to pass under. The hump in the middle keeps me from placing my hands close to the blade and I don't hold on top of it, usually further away. You can also place the hump further away if it suits you.
View attachment 108509View attachment 108511View attachment 108514View attachment 108515
It's OK I spotted the two push sticks!......It's a shame I don't have bigger and better quality digital images that could be attached to that article, .....
As you say Richard, Not too badly scathed "so far" ha ha. I read that article of yours and I thought it was very well written and particularly so as you had to keep your American audience on board – quite a tightrope to tread.You're a brave man, Ian. Putting something like that up was sure to elicit either some nit-picking responses, or downright critical ones. You seem to have escaped without being too badly scathed so far, ha, ha.
Here's a link to a table (cabinet) saw article from about twenty plus years ago to which I was asked to make a contribution. It's a shame I don't have bigger and better quality digital images that could be attached to that article, or be a supplement to it. I do recall that when the article came out it got quite a bit of negative commentary about the ridiculous(sic) 'short' fence advocated for ripping operations from a primarily North American user base of that woodworking forum - actually, the forum is still, unsurprisingly, almost entirely populated by North Americans, but some foreigners, such as myself, a well known Ocker, and a few other non-Americans chip in from time to time, ha, ha. Slainte.
I was taught to use two sticks at the age of 19 when I arrived at teacher training college (city of Leeds and Carnegy) and I’ve always done it that way, it seems so natural that I can’t imagine why all these other methods have come to the fore.It's OK I spotted the two push sticks!
I was prompted in the 2 sticks direction by a comment from someone on this forum many years ago - he said his tutor told him it was necessary. Maybe one of your own alumni spreading the good word?
Think of all those saved fingers! Well done!
Thanks yes I read this this morning, the bit I found disconcerting is that to remove offcuts from between the blade and the fence use the push stick if it’s less than 150 mm. And that’s the HSE! No way would I put my hand there at all.
Not sure if it was one of my graduates, Jacob; I've not seen more than one or two of them post here. It's possible though, I suppose. I do wonder if it might even have been me, but I think it's unlikely, and I can't recall ever really getting into any table saw usage discussions on this board, although maybe I have done so at some point.It's OK I spotted the two push sticks!
Proper crown guard on the riving knife would stop that happening....... as the blade passed through the last piece of the wood it tipped up as it went over the back of the saw and the blade caught the underneath shooting it back.
Rollers are good....... Or hopefully in the near future, a shop i can fit an outfeed table in for my saw.
