martinkearn
Hi,
I am a complete novice and have a small wood work project for a pegboard panel to be used at an exhibition. I have a 2340mm x 946mm pegboard sheet (3.25 thick) which I need to stand upright, but I also need to be able to split it into 2 pieces for transport.
My idea is to fix a wooden baton to the rear perimeter of the pegboard sheet so that the whole thing is rigid and will stand up when fixed to the exhibition panels at the top.
I would then chop the entire thing in half across the centre so that the two pieces can be detached and transported. My question is how do I joint the two wooden batons so they join end-to-end in a strong enough way that the structure is rigid when assembled but can be detached easily with nothing more than a screwdriver (or similar).
Any tips or ideas greatly appreciated.
I have attached a diagram which shows what i am doing from the side profile.
