Honeycomb structure
Arnold9801
26 Sep 2016
Cornwall
I'm a beekeeper in my spare time and with an up and coming local Bee/Honey exhibition, I would like to make a magnified bee frame exhibit.
Idealky I would like to make a 4:1 scale model of the frame. They actually measure approx 380mm x 250mm.
The hexagonal cells of the frame will need to measure approx 20mm and I'm looking for so e form of hexagonal structure of this size to simulate the wax cells in a typical hive frame.
Does anyone have any suggestions of such a product I could use for this providing me with cells of this size?
See the two photos below.
To make each cell would be to time consuming!
Arnold9801
I recall visiting an aircraft maintenance and refit hanger and seeing large sheets of lightweight honeycomb material used for internal walls.
Colin
A bit strange this….but….the core structure if Ikea desk tops is this shape….if you could find one that is being thrown away…..
Is there a material available in tubular form which you could cut into short lengths and cramp together in a frame?
Don't know what you mean, but I'll research it to see if I can get a photo of it and go from there. Thank you.
