NeilO
Guys and Gurus....
I have tried to follow Dave R`s tutorials, but the X,Y,Z factor is not sinking in...
However i did manage to start a design for a new workbench (after following several posts on making as opposed to buying), my problem, or question is when using multiple components , should i be placing each component on a new layer ( i.e front leg assembly, rear leg assembly and so on..) the problem being if i make a mistake and try to erase it i lose more then i intended, bearing in mind i have it all on the same layer at the moment.
i have finally sorted out how to "draw" to a specified dimension , thanks to Dave R`s tutorials, so i figured a simple task of a workbench would be fairly easy :shock: boy was I wrong......
so if anyone can point me in the right direction :?
Neil
Neil
