Help or advice please getting small display stands made
Fairweatherer
24 Jul 2016
Wiltshire
Hello,
I've been trying to source a supplier for display stands/mounts for sculptural or ornamental wood. No one seems to stock them so looks like finding someone who can make them. Sizes will vary, but simple enough design, approx 8"x8" metal plate with two 18" vertical metal rods (6mm) extending upwards. An idea of what I could expect to pay would be a start. Any advice be much appreciated.
Thanks,
Wayne.
Well your material costs are virtually nothing if you want them in mild steel....just search for the thickness of plate and have them cut to size on eBay get some rod in the max length you need and invest in a hacksaw..
Next drill a 6mm hole in the plate and get a cheap welder to weld the rods in.
If you wanted someone to make these I would charge £5 each for a few but postage would kill the deal
Ian
If you wanted to eliminte the welding element, you could drill the plate and tap the hole, then cut a short thread on the bar to screw in....
