Hi Roy and anyone else reading..
I started work on the horsebox the other day which basically involved removing a load of the blue carpet lining which can be seen in the pics..I got in a bit of a mess because the cupboard and set were fitted after the walls were lined so I had to take them out to get the carpet off the walls..I haven't got any pictures yet..Removing the carpet was a doddle...removing the aluminium trim which was glued to the carpet was a lot harder than I expected, but brute force prevailed
So what was I left with...you guessed it..a load of foam backing stuck to the 9mm ply :evil: ....So off I started with a wallpaper scraper...That was as much use as a chocolate fireguard but as I was working away from my workshop I didn't have my other tools at hand...So..Today I went back armed with a decent wirebrush and that worked a treat..I also bought a replacement blade for a floor scraper and used that after I had got most of the foam off with the brush and it worked pretty well...I am just contemplating having a quick go over with my belt sander to get it nice and clean before I start trying to glue to it...Obviously I will have to take it easy as I don't want to sand through layers of ply
I have noticed some area where damp has obviously got in so I will need to resolve that before I move forward..I am going to remove the side door and refit it making sure there is plenty of sealant around it as there is currently a gap at the top..Will also do the same with the windows...
I will get some more pictues when I am next over there to show it better..
So now I am in the position of preparing to move the bulkhead between the living quaters and the horse bit...Although I have a problem I need some help with please:
The 9mm ply on the living quaters side of the bulk head needs to be removed to gain access to the coachbolts...But instead of being held on with self tappers it has been nailed on :evil: ..Now apparently these are a special type of nail (they have a "P" on the head) which works in a similar way to a cavity fixing when nailed into the steel section? I have no idea how to get them out..although I will admit to not having tried the conventional way believing that these were special nails but I guess I should try just pulling them out...if that doesn't work then does anyone have any idea how to remove them, apart from scrapping the wood or getting an angle grinder on the nail heads..I don't need to reuse the wood as I will just reply but I am sure there must be a scientific way of dealing with these nails?
Any advice is much appreciated.
Timmo
