I was wondering if anyone has applied harwax oil to hand planed surfaces.
I am trying wood wax finish extra thin on some cherry, currently testing a sanded piece and a planed so far the application seems to have gone the same for both and at this stage 3 days wiped on 3 coats now will wait to fully cure. They look almost identical.
The instructions say sand up to 240 furniture -150 max for flooring. I don't really understand why this is except for that marks/wear/scratches are less visible on duller more matt lower grit sanded floor.
Or is there some real difference in what is happening with the finish, does it perhaps work more effectively if it's sat inside the scratch sanding valleys?
