Fixing a Chapter Ring
bodge
18 Feb 2012
Long Eaton
Hi everyone, I wonder if anyone can suggest anything for this. I turned a couple of clock faces, one from Maple and one from Willow. I'll admit the Willow is probably not too well seasoned which could have a bearing, but the Maple is fine. I've tried gluing the aluminium chapter rings onto the wood and they keep buckling overnight. I have tried superglue (probably a bad idea anyway), pink grip and good old silicone with the same results each time. At first I thought it was because it is pretty cold in my garage and a lot warmer when I bring them into the house, but even if I let the pieces acclimatise for a day or two in the house before gluing the result is the same. I thought the silicone would be flexible enough to give, but apparently not.
What does everyone else use to fix chapter rings? and am I doing something dumb (as usual) which is causing this?
Thanks everyone.
I'm afraid there you have the answer.
Willow is almost always full of water when it's felled (up to 100% MC) and therefore takes forever to dry.
I'd see if you can do a swap with someone with a woodburner - swap your willow logs for the pick of their log store. You're more likely to come off the better IMHO. :wink: :wink:
Jon
I think you need to let the wood acclimatise for much longer. The aluminium buckling is a good indication that the wood is still moving. By the time it has stabilised you might find your wood is too oval and may need reshaping anyway.
