First post - building a carved-top guitar, and other than knowing what the top will be (a bookmatched solid carved rosewood top), the rest is up in the air. Not for lack of wood, but because I also intended a one piece carved rosewood neck, perhaps over either a lightweight mahogany or limba back. However, the rosewood neck blank that I bought "dry" is wet, and I have another 8/4 rosewood bit as well as a couple of maple carved wood top sets, so that can be for another later build after it's both dry and confirmed to not have bad seasonal behavior.
The neck for this guitar may end up being laminated curly maple - I have plenty of mahogany neck blanks, but long term stability in a les paul style guitar is better with laminated maple necks (dips, body hump, twist).
So, thus far, all I've got cut is the resawn top set.
8/4 quartered rosewood is uncommon enough that getting a perfect set that doesn't have some flaws (this set has a couple of small wormholes and the crack that's glue stabilized here) may not be realistic, so I'll work with what I've got here and try to mitigate the flaws or locate them where they won't cause a problem when the top is carved.
This wood is relaxing a little bit while I see if and how it moves over a couple of weeks. It won't matter once it's glued and laminated to a body, but I don't want it to go bonkers between being joined and then attached to a body.
The basis for copying this will be an older style les paul copy from tokai (older style meaning that tokai's copies - some of them - are more faithful to earlier angles and proportions of original gibons than current gibsons are, and they cost less - so to buy one, take measurements off of it and then resell it yields a better guitar and the outlay/risk of a big change in the market is less. tokais aren't sold in the US due to the fact that they copy the gibson peghead scroll, so if one wants one at hand at a reasonable price, dealing with japanese dealers or japanese auctions is a good idea. Sellers in the US price them about the same as gibson (or try- about double the price in japan). Buying a 60s les paul at this point to refer to is out of the question - they can be as much as a car, and there's probably some fraud with fakes or unmentioned modifications or refurbs.
It seems more interesting to make one of these with a rosewood top, but we'll see - maybe the fact that there are few (other than a bunch of gibsons made mostly with flatsawn rosewood 40+ years ago) is a sign.
This thread will progress slowly as I've got other stuff in the works and the first four months of the year is always more than full time at work. The goal is to do much of the work by hand (though this guitar type was designed to be made with power tools), not have the guitar look like it was made by machines, but also do the work neat enough that it doesn't scream "lumpy and sloppy...made by hand".
