Hello
To those that work on fitted furniture regularly. After advice on here I've successfully used the methods
from the likes of Jason B etc on Infill pieces to the sides of alcove work so thanks for all there help I've had in the past.
I usually use a piece of 6mm or 12mm for the front (shown) piece and a piece of 18mm for the part of the L shape that hides in the infill gap. I usually glue and pin the front piece over the hidden piece.
Ive found whilst this method works a treat (especially if you want the scribe to fall flush with the door) when I screw through the inside of the carcass to fix the infill it tends to twist the piece out of alignment.
I can't work out what Im doing wrong but its always a struggle to get it to fit perfectly.
Can anyone offer any decent techniques that Im missing......I.e placement of screw holes in the carcass etc or should I
screw the L shape infill together to offer better holding power. Im always struggling with this really need some help
Tel
Tel
