Woodworking Chancer
Hi everyone,
I'm a DIYer who's in the process of making my first inbuilt wardrobes. I have the carcasses all built and ready to go, and I'm installing on a ladder plinth.
I'm suddenly doubting myself on infill strips etc... I'd like them to be flush to my doors, which are currently going to be slabs (but I might later on change them to shaker). When I did the design in Sketchup and the way I've done the plinth, I was envisaging the base to be like a kitchen with a "toe kick" kind of infill strip at the bottom. But now, I'm not sure how all that would join together, because the MDF strip along the base will be inset by a few centimetres, while the side infill strips will be flush.
If I continue with this - should I end the side infill strips at the same height as the bottom of the doors (I feel like that would look a bit odd)? Or continue to the floor, and somehow join them to the base filler sat a few centimetres behind? I've attached two pictures of the same thing from different angles from my original Sketchup design. As you can see, in Sketchup I just continued the side strips to the floor (they won't be quite as wide as those but will be around 7.5cm wide.
OR, would I be better off bringing the bottom strip forward to also be flush? I also see many wardrobes use skirting on the bottom. If I did this, would I attach that over a flush strip so that it sat proud of the doors?
Any help and advice much appreciated. I think I can figure how to scribe and attach them using an L shape and screw from inside the wardrobe - although I wish I could find the thread as I'm sure I saw on here a good thread about infills where someone did a Sketchup drawing to support the OP to see how to use an L shape infill and scribe it.
Thanks in advance for any help from the experts!
![1698155545561.png 1698155545561.png](https://cdn.imagearchive.com/ukworkshop/data/attach/149/149585-1698155545561.png)
![1698155572569.png 1698155572569.png](https://cdn.imagearchive.com/ukworkshop/data/attach/149/149586-1698155572569.png)
