Hi all,
I thought I’d create a post (not a pun) as it’s something I find time consuming and can be abit of a head scratcher as it’s a crucial part of the setting out. You only have one attempt at getting it right otherwise, it’s a nightmare.
The corner post - The majority of kitchens I’ve fitted it arrives pre-made and you just have to attach to the side of a door or to a large base unit, fixed to mullion to form the corner which usually has a 450/500/600mm door beside it. Which takes all of the thinking and playing around out of the equation.
Some of the cheaper/lower quality kitchens supply a décor end panel which you have to rip down to form your own corner post. They often don’t come with a 18mm/12mm blanking panel which you usually screw your corner post to for your base units. They generally give you a 3mm MDF panel, you’d need to trim and screw to the carcass after the corner post is installed, often fiddly and annoying.
I recently installed a Wren kitchen which had a ‘floating corner post’ for the wall units. The wall units had a handle-less rail fitted to the bottom of them. which made it difficult to fix the ‘floating corner post’ as you cannot screw anything to the bottom, as the front edge has the handle-less rail. It was definitely more work than it was worth.
I managed to do it in the end, but how do you guys approach your corner posts, do you have any tips or ways of doing them?
(obviously keeping the post flush with the doors, 2mm past the carcass)
![cornerpost.jpg cornerpost.jpg](https://cdn.imagearchive.com/ukworkshop/data/attach/136/136365-cornerpost.jpg)
