henton49er
February’s Challenge is a fisherman’s priest. This is an item which is used by anglers to rapidly despatch fish they have caught into the great fishpond in the sky. There are usually two sections to the priest, a handle and the bit with which you hit the fish, but it is turned from a single piece of wood.
If in doubt see Google images :-
https://www.google.co.uk/search?q=fishe ... 76&bih=638
Richard Findley has kindly agreed to be our judge for this month’s Challenge. There will be a plaque for first place, kindly made for us by forum member Daven. Many thanks to both. =D> =D> =D>
Challenge Requirements: A Fisherman’s Priest
This month’s rules are:-
The Challenge is open to anyone and everyone
Your entry must be new and made specifically for the Challenge
Entries must be turned on a lathe using woodturning tools.
There are no minimum or maximum size restrictions, other than practicality for use as a priest.
No decoration, colouring, piercing or texturing is allowed. We want to see your turning abilities!!
Because this month’s Challenge is a relatively simple project, Richard has advised that he will be critical over little things. Entrants should make sure curves are smooth and flowing, there should be no torn grain and in particular he will be looking at the parting off to see how well it has been done. He will also look to see that a suitably “heavy” wood has been used – a balsa wood priest would not be of much use, after all!
Please post 3 images of your work along with a brief note about how you made it, what tools and finish you used, what wood you used and the objects dimensions etc.
1 showing a general view
1 showing an end view in close up
1 showing the other end view in close up
Image size - please use image size 640 x 480 0.3 mp, as in previous challenges
Please upload your pictures and description between 10pm on the 26th February and 10pm on the 28th February.
Please also send me a PM giving me your own opinions of 1st, 2nd and 3rd places amongst the entries (other than your own) between 10pm on 28th February and 10pm on 2nd March (for me to compile the entrants’ scoring).
Any queries or questions on this month’s Challenge, please use this thread to ask.
