giacomo
Hello everybody,
I have a little problem about veneering a panel with feathered Mahogany, the surface is flat and the problem is that the only mahogany I found has many cracks and a lot of waves, fortunately no holes and\or parts missing.
The piece of furniture I'm restoring (secretaire, we call that kind of piece) has four strips of veneer and I'm going to do the same on the front panel.
I only use animal water\based glue and I thought to wet the veneer and press it between two flat surfaces until nearly dry, then starting the job.
But something in my mind tells me I'm making some mistake, any advice about it?
thanks in advance
Giacomo
thanks in advance
Giacomo
