sploo
Somewhat extinguished member
I have a partially broken universal joint from a ~40 year old table saw (see below):
The central section had seized solid, and unfortunately adjusting the blade tilt (using the threaded rod + UJ shown above) has caused part of one end to shear off.
It looks to be 3/4" OD, with a 5/8" bore. I'm thinking I could drill and (likely shoddily) mill out enough from a piece of 3/4" steel rod to make a replacement for the damaged end. However, would mild steel (e.g. EN1A or EN3B) be strong enough? I can get some EN8, but would that be feasible to machine with HSS drills and cutters? (yes - I am a noob metalworker)
