chrissteele
New member
Hi folks, have one where the bearing on the drive side of the armature has failed. Problem is that I can't get the drive pulley off after removing the LH thread securing bolt. I suspect it's also LH thread, as doesn't seem to be splined or have a woodruff key, or appear to be taper fitted.
Gather there were two drive belt variations, and my one uses a grooved belt - Discovered as bought the wrong one last time when another bearing failed.
Thanks for any thoughts - Chris.
