Thanks Robbo3 for your reply will contact Robert sorby to see if part is availablePresumably nothing to do with the lathe but it seems the broken part is from a Robert Sorby Patriot Chuck.
I can't make out if it's the chuck insert or the drive pinion that's snapped. Either way, if spares are available they are only likely to be obtained from Robert Sorby.
- Robert Sorby | High Quality Woodturning & Woodworking Tools
If the broken part is the insert you will need to know the thread size of your lathe to get a replacement.
Chuck manual & Refurb article attached
Pulled apart re greased back together all like new nothing left over on the search for broken part thanks Robbo3Thanks Robbo3 for your reply will contact Robert sorby to see if part is available
