My SC2C has a wagon travel of 1925mm, but the useful cutting length is 1600mm, so I can easily crosscut a full sheet of 2500x1250mm (a little larger that 8x4) plywood. If my shop was larger, I could lock the slider and rip a full sheet, but the shop walls are too close to allow a full sheet to start before the blade and finish after the blade. The slider crosscut fence will accommodate up to 1660mm to the left of the blade and the rip fence up to 900mm to the right of the blade; however, due to limitations of my shop, I am restricted to 1410mm to the left of the blade.
Here is a picture of my saw the day it was commissioned in October 2017 while I was still in the early phase of building my shop. I have since replaced the optional overhead guard with the standard guard that attaches to the riving knife. The overhead guard frame attaches to the right edge of the table and restricted my use of the table for other things. This picture also shows the slider crosscut fence on the infeed side, but I changed it to the outfeed side because I prefer that setup.
Here is a picture of the shop from earlier this year. The saw isn't shown as well, but you can see the change in the blade guard and the slider crosscut fence has been moved. I cut all of one of the 19mm (3/4-inch) plywood sheets for the miter saw workstation using the SC2C. It was not fun bringing full sheets down the stairs to the basement, but once there, I cut them down to manageable sizes.
These saws do not have a trunnion for the blade tilt. Instead, the motor assembly is attached to a pivot and a lead screw is used to change the angle of the blade. The main and scoring blades can be tilted from 90 to 45 degrees. I haven't done much cutting less than 90 degrees, but when I turn the handle, the blade tilts and it is accurate and repeatable. Here's a YouTube video showing the smaller SC3W where he describes the blade pivot.
