Chris_belgium
- Joined
- 7 May 2006
- Messages
- 272
- Reaction score
- 0
My dust extraction sucks!
Been working on a dust box thingie, after doing some testing I'm very dissapointed with the performance. Problem is I have no clue at to what the problem is.
This is the extractor I'm using, it has a 120mm outlet wich is 'plugged' straigth into the dust box
Problem is I have no clue as to what 'performance' this extractor has, maybe someone with a similar extractor (impeller size, motor hp) could offer some info.
Impeller is 19cm diam.
Wich way should the impeller turn clockwise or counterclockwise? And should the motor be wired up in the delta or in the star configuration?
Motor is 1,5hp
So the 120mm outlet of the extractor goes directly into the box, then there are 2 100mm outlets, one of the outlets is connected to my p/t with a 100mm flexi hose, the other outlet has a reductor in it from 100mm to 32 mm wich has my 4m long vacuum hose connected to it. Performance is very very weak.
My main question is, would a motor like this be sufficient for a system like this or do I need to buy a bigger motor?
Another thing is there seems to be a lot of room around the impeller inside the housing, I am not sure if this is a home or factory built housing around the impeller, so it could be that the dimensions of the housing are all wrong and that is my problem.
Anyone have a idea as to where the problem lies, any help as usual is greatly appreciated,
Chris.
Motor is 1,5hp
Chris.
