got wood
Hi all..
After some advice again (one day I may be able to give some back )
I will shortly be embarking on a set of built in wardrobes. They are going to be 19mm ash veneered carcass ,solid ash doors (19mm) with 9mm (or maybe 6mm) veneered mdf panels.
My question is this (I kinda think I know the answer already though!) Will this joint be strong enough for the doors :
Sorry about the pic size (big is here- http://farm3.static.flickr.com/2235/166 ... 5ba4_o.jpg if you cant see the small one!)
The panels would sit in the same rebate as the tenon.
This would be easy to do on the router table, as would a similar setup using a rail and stile bit set, but I prefer the clean lines of a rebate.
Personally I think I will have to mortice and tenon join the ends, as there isn't alot of gluing area on the tenons.
The door (9 of) will be approx 78" x 17" with a rail half way up to seperate the two panels.
There will also be topboxes (bridging unit?) above each that measure about 17" x 17" (I like imperial units, but tend to migrate now and again!)
The above joint is the same as my kitchen units, but they are obviously a lot smaller.
Any advice gratefully received.
Jamie
Jamie
