seaco":3qx6yvyw said:
Rorschach":3qx6yvyw said:
Interesting, look forward to seeing it progress.
Off and on (while daydreaming) I have been thinking of ways to make a vertical setup for a tracksaw. Partly to save the need for an 8x4 work surface when breaking down sheet goods and also so you only need 1 saw and you can use your track for the vertical or standard horizontal use.
The only problem I see is holding the saw in the track when vertical, if you want to be able to use the track as it won't be held, unless you physically hold it in the track while in use?
The system would be set at a slight angle so gravity would help keep the saw on the track. But yes at the moment the idea is that you would hold the saw in place, maybe with some kind of "
sky hook" type system to help off set the weight of the saw.
