Definitely not Mahogany !
dm65
27 Dec 2012
Leeds, West Yorkshire
Evening all
Been given some wood today - removed from a doorframe and was given it as Mahogany
First sight told me it wasn't but had to wait till tonight to clean some up
Straight after grot removal with the belt sander -
And after a little planning -
Sawdust is yellowish which made me think of Iroko
The board also feels a bit greasy after planning
Come on then, who's first ?
Bob's first - go Bob =D>
Here's some rough cut end grain
Here's another shot with a piece of actual Mahogany on top
Real men do it in their slippers btw 8)
I`ll say Teak, Teak is a funny wood some times it can be hard as iron and the the next piece can be like putty.
When you work it and rub you hand on it it feels greasy and can some times stink to high heaven. What makes me say Teak is when you look at the pic with the end grain in it on the right hand side on the long grain you can see a streak of white this shows up in the long grain some times it looks like powder and sometimes looks like grains of sand but it is actually part of the tree ,if you have to work that it takes the edge off your tools in no time at all.
Because of the natural grease in the wood it makes an excellent out doors timber left to its self the color fades and it goes gray.
It might be Ipe, although colour is a bit clear . Is it somewhat fibrous in texture, although quite hard? (tungsten carbide tipped tools are recommended for machining Ipe). If it is Ipe, be careful about the yellow dust, it is toxic and allergenic.
Thanks for the responses everyone - I've never seen or worked Teak and seem to remember Iroko being more reddish in colour
The wood does feel greasy to the touch after planning - didn't check after sanding - and I found it pretty easy going though couldn't get full shavings like I expected as the grain seems to change direction often
Sanding and sawing produces yellow dust or is it a light brown ?
I think we can discount Ipe as I don't find this a particularly hard wood (shame though, sounds exotic :) and as you can hopefully see below, it's not fibrous - the opposite in fact, look how it's snapped away pretty clean
:) not sorry at all, never had any teak before and as well as the piece I have cleaned up and modelled for you, I have two boards almost 6ft by nearly 7x2
Wonder what to do with it now
Good idea Phil, but I'll keep these till I get another place with a garden
Went to a site today where there is a guy who knows his wood and he is definite that this is Teak so I think that's timber well saved from the skip !!!
Thanks again everyone for your comments
