CUTTING planer blades
kityuser
12 Jan 2003
ok, so I got some custom blades for my thicknesser planer, I now need to find somwhere to machine the 4 slot/holes in them for me.
I have an old blade as a pattern, just need to find somewhere that can cut the new HSS blades for me.
any ideas anyone, I have been told by somebody that the blades are SO hard that I`ll need them laser or water cut........
cheers
steve
Chris Knight
14 Jan 2004
SE London - NW Kent
Steve,
You could try RA Palmer at Northfleet/Gravesend
R A Palmer & Son
Unit K3, Kent Kraft Industrial Estate
Gravesend , Kent DA11 9SR
They are basically a sharpening service but they should be able to advise, even if they can't do it.
ike
24 May 2004
Kityuser,
Drilling/milling HSS is normally done with the metal in a soft state. After hardening, the blades are then finish ground. If your blades are not yet hardened, you should be able to get them drilled/slotted at any general machining shop - yellow pages maybe?.
Midnight
11 Oct 2003
Scotland
there's a thought.. A while back, Screwfix sent the wrong set of replacement blades for my thicknesser; way too thick and no slots to clear the guide pins. If I could get them cut somehow, they'd make perfect blades for some custom tools.
Dewy
11 Jan 2004
Gloucester
If the blades are already hardened you would need to get the holes spark eroded in the correct places. It's not a very difficult task once copper electrodes are made to produce the holes but is likely to be rather costly.
kityuser
12 Jan 2003
apparently it should`nt be a problem to grind slots into the blades rather than holes i.e. right to the back of the blade.
I suppose I could then get the back of the slots welded up?? i.e. giving me elongated holes..........
ike
24 May 2004
PLEASE DON'T CONSIDER THIS!.
It will be difficult to end up with a balanced pair.
Welding will weaken the integrity of the blade. Were talking about razor sharp metal spinning at 5 - 10000rpm here.
IT COULD PROVE EXTREMELY DANGEROUS! :shock:
Ike
A
Anonymous
Guest
Steve
I think spark erosion is the process you need if they are already hardened. Look in your local yellow pages
