Hi again
Batfink.
As said there have been numerous posts about sharpening over the last few months.
What you first must realise is that every woodworker has their own preferred way to do things, and sharpening is just one, so with tongue in cheek.
IMO one good source of information is
here, keeps everything down to a simple level, shows the setting up of the grinder, then goes on to show how to construct a sharpening station from basically wood off-cuts. Once completed this set up will allow you to sharpen all your chisels, including spindle and bowl gouges with long grinds. The tagging when moving forward through the article is a bit awkward, once you have read the page you will find just beneath the end of the article, a very small '
home' and '
next'. This is where you move forward through the tutorial. A few folks couldn't find them.
Also listen to the voice of reason before opting for a Tormek or something such like. They are great pieces of kit, but certainly not needed for woodturning. If you want one great go ahead, all I'm saying is that for woodturning it is a luxury. The above mentioned jig will set you up with all you will ever need.
Good luck!
