PerryGunn
First off, I say cheap but it's only the remote control part that's cheap - circa. £25 - you spend whatever you like on the actual dust extraction setup - but this may help anyone who needs the functionality
First... some background
I only have a small home workshop so nothing that requires large-scale chip extraction and my vacuum needs were adequately covered by an old Henry (which I modified to always start in high-power mode) and a Dust Commander cyclone with a 30L metal drum. To cut down on noise the vacuum and cyclone are in the garage which is separated from the workshop by a brick wall - the Henry power and dust tubes run through the wall and power to the Henry was from a wall switch in the workshop.
(NB This setup has now evolved to include rigid tubing, multiple outlets, blast gates, and more vacuum 'suck-pressure')
The problem...
This worked well but I got fed up with having to walk over to the switch to keep turning the vacuum on and off - more awkward than you'd think in a small workshop as the limited space means that there's often stuff in the way.
I started looking at ways of switching the vacuum on and off automatically. Intelliplugs and Vacs with power take-off are always mentioned but power take-off doesn't really work if you have the vac the other side of the wall (trailing sockets are a horrible trip hazard) and Intelliplugs need you to always plug into certain sockets - when I built the workshop, I installed lots of sockets so there would always be power where it was needed without long cords trailing all over the place.
A solution
After hunting around, I found a 240v 40A-rated 433MHz remote control relay which came with a couple of small 2-button (ON/OFF) keyfob remote controls, it was cheap enough at around £20 to take a punt so I ordered it. A bit of testing with it plugged into a mains socket and controlling power to a trailing socket confirmed that it worked as advertised so it became a permanent part of the setup. When I'm working I hang one remote control around my neck on a very short lanyard (so it can't get caught in anything) and just press the buttons to start/stop the extraction - it's manual on/off rather than automatic but, for me, it works very well.
Parts & Installation
The relay & remotes https://www.amazon.co.uk/gp/product/B07CTL3TG6 or https://www.amazon.co.uk/dp/B07SCZ8V1W they're both the same thing and are £21 at the time of writing this
The relay is single pole and only switches the live line, neutral is direct pass-through to the output (think of it like a lamp that has an in-line rocker switch on the live), you need to ensure Earth continuity around the relay (Wago connectors are good in an enclosure). The relay always defaults to the 'off' position when power is applied (even if it was 'on' when the power was switched off).
It needs to be enclosed in a suitable box as the terminals have little in the way of protection from small pointy objects/fingers and, in a workshop, it's best to keep the dust away - I used something similar to https://www.amazon.co.uk/gp/product/B07MV9Z26Q but it would fit in a double backbox with a front blanking plate.
You'll want to have a fused switched power supply to the relay so you have a 'master switch' for the vac supply. I always turn the vac power off when I finish using the workshop . I have a switched fused spur connection but a 13A mains plug in a switched socket will work just as well and avoid any Part P issues. I would recommend wall mounting the relay enclosure and ensuring you have proper strain relief on the cables in/out of the enclosure and ensuring that any surface mounted cables are properly enclosed/protected.
Wiring is very straight forward - apologies to anyone who's colour blind as I've used Red (Live), Blue (Neutral) & Green (Earth)
Hope that helps somebody
The problem...
A solution
