Chair Doctor Glue
Newbie_Neil
27 Jul 2003
Nottingham, England
Hi all
If anyone ever has to refurbish chairs, that someone else has made, because the joints have worn loose over time then just invest in Chair Doctor glue from Brimarc.
It's not cheap, about seven or eight pound iirc for a small container, but it does what it says on the box.
Neil
Alf
22 Oct 2003
Up the proverbial creek
Also handy for tightening up loose tool handles that someone else has made (obviously...) :wink: So it also does what it doesn't say on the tin.
Cheers, Alf
Chris Knight
14 Jan 2004
SE London - NW Kent
Also handy for wicking into tight box (comb) joints after assembly with a mallet.
And have you noticed, it looks and smells just like a waterborne acrylic - Bolloms's Hydrocote to be exact. It has that same bluish sheen too.
A
Anonymous
Guest
If this is the Veritas Chair Doctor glue, it also has some gap filling properties, cos it causes the wood to swell an amount; it won't cure a really sloppy joint, but can help with those that are a little bit loose.
