sams93
I seem to have made a habit out of picking up old machines in need of a bit of work...
A local workshop was getting rid of it's old bandsaw last week and I picked it up for slightly over £100 which I thought was a steal!
Its a Centauro 400 SSP, It says 'Anno di Construzione - 198' Which I assume means year of construction 198 - not sure if that is 1998 or 1980?
It 'works' as it is, but there is a moderate amount of blade vibration.
My 'workshop' is an 8x6 shed at the moment... so clearly it won't fit in there at the moment . It's in my parents garage for now until I get a larger workshop (or I might manage to squeeze it in!!).
I have emailed Centauro but I'm not sure I will get a manual or anything off them, It doesn't seem to be a common brand or model in the UK (scott and seargent do stock Centauro machines) so I haven't found much information on a search about them - there is one really old inactive thread on here where someone had bought one but no follow up and they are no longer active on here.
I wondered if anyone had any experience with this or a similar machine, anyone had a manual for it, and then some generic advice on the work I will need to do to it!
I'll attach photos shortly!!
- The top guides need one of the locking screw threads which holds the thrust bearing in place re-tapped, as it slips out of place when tightened.
- The bottom guides need replacing, but the bloke who sold it to me gave me a set of bottom bearing guides which I will try to fit.
- The tyres are quite worn so I might try to replace them.
- The top wheel seems very slightly loose and there is a little bit of squeaking at times when that wheel is moved by hand - I wonder if I will need to change the bearing for the top wheel.
- Motor seems fine.
- The table needs a bit of a clean up but nothing major.
- I need to make a new dust extractor port for it.
