justinpeer
Had a cheap step drill fail to do the job so bought one from UK Drills (bought through Amazon), who I've seen mentioned on here before, thinking it would be better quality but it's worse. I'm trying to drill some holes in 1mm steel to mount some speaker connectors. It drilled the first 2mm hole but after that it refused to go any further, just pushed the metal down without cutting. I'm using a pedestal drill with cutting fluid but no joy at all.
I have HSS drill bits up to 14mm but would have to buy several more individual bits to work up to a 24mm hole I expect and figured an HSS step bit would be much easier and more useful in the future.
Are there any good known brands out there or should I just get a blacksmiths 24mm bit and use that from 14mm straight to 24mm.
Thanks.
Thanks.
