Quantcast
Bearing equivalence
Deadeye
21 Aug 2017
Buckinghamshire
Quick question.
Just measured and the "imperial" bearings are measured in metric.
Can I simply substitute sealed?
TheTiddles
14 Oct 2007
Wiltshire
Sealed vs open, yes you can interchange them.
If it’s 25mm ID onto a 1” shaft, then it shouldn’t fit, are you sure they are imperial if they List as metric?
Aidan
heimlaga
27 Sep 2009
western coast of Finland
We need some more facts!
What is the application?
How were the bearings lubricated originally?
What type of bearings.
Imperial bearings are not interchangeable with metric. If the dimensions are the same someone somewhere has been pulling someone elses leg at some point and either the old imperial bearings aren't imperial or the new metric bearings aren't metric.
I have seen quite a bit of damage caused by the sealed bearing hype. In some places they are adequate. In some places they are better than anything else. In some places they can cause damage that costs thousands of euros to repair in a matter of weeks.
For instance you cannot replace self aligning spherical ball bearings with sealed grooved ball bearings.
For instance there are some uses where open grooved ball bearings will last at least 10 times as long as sealed.
Deadeye
21 Aug 2017
Buckinghamshire
Trevanion":26ubtlbd said:
All I can say is... Eh What? :lol:
Hehehe. That'd be fair.
The longer version of this:
I'm cleaning up an old planer (the bigger version of the one I did before). Evrything is imperial. I got the bearing out and thought it was imperial 1"x2"x3/4" probably; I didn't measure, just got the code.
The code took me to this:
https://www.qualitybearingsonline.com/l ... 5x52x18mm/
Which confirms "Imperial" but then lists as 25x52x18.
I thought that might be sloppy listing, but no, the "Imperial" bearing is indeed nicely metric.
That opened more options (for deep grrove bearings oif that size), including sealed-for-life.
So then my question became whether it mattered sealed vs unsealed. The current ones are unsealed. They also hold the block and so reeive quite a bit of dust potentially.
I think I read on here someone saying they always use sealed (perhaps on a Union raduate thread). Is there a downside? They seem to be slightly less expensive.
Sorry for the mental spaghetti of the original post!
Eric The Viking
19 Jan 2010
If the code is the same, so the bearings should be also.
North America, a reasonably large user of bearings, is still imperial for much of its industrial kit (stuff in use presently, rather than brand new, for the latter I don't know), so imperial bearings are available. So find a NA bearing supplier and look up the code on their site, and see if what specs they quote match with the UK/EU supplier you have already found.
It's also worth taking a bit of time to understand the letter suffixes too. For example, there are high-temperature bearings designed for use inside engines, where the bearing only achieves the correct tolerances _after_ it has got pretty hot (otherwise it has excessive play). You probably don't want those in a woodworking machine, unless they are explicitly specified by the manufacturer!
That's a bit annoying, in that classic motorbikes in particular are a market for imperial bearings, but I suspect probably only the high-temp type.
But... at a guess, the bigger the imperial bearing is, the more likely replacements can be had, on the basis that smaller kit is likely to have "gone metric" a long time back. Worst case you might need to source in the USA and take a deep breath before shelling out for the cost - but you should get them.
All my kit is metric presently, but I usually replace the chinesium ones with SKF oil-sealed ones, partly for quality and partly for ease of cleaning - there is negligible risk of forcing sawdust and other stuff into the ball races. Given the size of machine, the bearings on my Kity's planer block are huge, and show no sign of play, although it's probably at least third-hand.
In my very limited and amateur experience with both belts and bearings you need to 'turn detective' before ordering. Hope you find what you need.
E.
Deadeye
21 Aug 2017
Buckinghamshire
Hi Eric
Unfortunately the code is from RHP - who were bought out a long time ago.
I found somewhere that 4205 ATN9 are equivalent... and that's what has given all the sealed/non sealed options.
deema
14 Oct 2011
chester
I’d use a 6205 2RS which is a bog standard bearing with a 3mm shim washer to make it 18mm rather than 15. The price difference you will see is massive. Shim washers are standard stuff. For a PT I’d just use standard clearance bearings as opposed to C3
Myfordman
AKA 9Fingers
19 Jan 2013
Southampton area
The other thing to consider about sealed or not is how the machine was designed to be lubricated. If it is meant to pressure greased/oiled then you don't want seals as this will stop fresh lube entering the bearing and flushing out the old, potentially dust laden lube.
Trouble is few woodworkers in my experience undertake regular lubrication of their machines!
TheTiddles
14 Oct 2007
Wiltshire
Yes, I should have clarified, if it’s just installed and left then sealed can replace open, but if it’s actively lubricated you might be better with open.
Bearings are a lot more complex than they appear, in so many cases they are incorrectly specified, a bit like bolts, look simple, but more to it that there appears.
Imperial is a funny thing... it’s been metric for the last century or so, just a conversion of it and many “old” things were designed in metric long before the 1970’s.
Aidan
J-G
20 Jan 2014
ATHERSTONE
I don't think I would place any trust in any company that states 'Imperial' and then goes on to give a size in mm! Either they don't know or just don't take care.
With all the caveats regarding lubrication and high speed acknowledged - you might like to look at 'Simply Bearings'
https://simplybearings.co.uk/shop/produ ... 355&page=3
I've tried that link using [Preview] but it will only take you directly to 25x52x15 bearings so you just need to specify 'width=18' in the options.
No connection - just a very satisfied user of Simply Bearings on many occasions.
