Glynne
I started a separate thread last week when my starter capacitor blew up and thanks to CHJ (Chas), I've now managed to sort this.
However, when using the lathe today I noticed it is incredibly noisy. Given that it is a budget lathe it has never really been that quiet and add to that it is about 15 years old then I know I can't expect silent running. But now it is really noisy to the extent that it is off putting. Additionally, the motor gets really hot and whilst the manual suggest it can run at 60*C, I'm guessing it is probably hotter than that.
So I removed the headstock cover, motor front cover & fan and the the belt.
The headstock spindle spins virtually silently with negligible play but the motor spindle is very noisy even when turning, let alone spinning by hand. I can only describe the noise as sounding "dry".
So unless I have missed something, this sounds very much like the motor bearings have gone?
The main questions are: -
How easy / difficult is it to replace the motor bearings? The manual suggests they are sealed for life but I don't know whether that means the cannot be replaced?
It it a DIY or professional job and how much is it likely to cost?
Is it likely to be worthwhile given that the lathe is 15 years old is an old budget model?
I'm also thinking that I shouldn't use the lathe for the time being given that I'm only going to generate excessive heat and, apart from the safety consideration, I'm likely to burn out the whole motor if the spindle seizes.
Any advice would be appreciated!
