Alex
When my Ct150 arrived I didn't need to do anything to the tables as they were all set-up. But then I moved it by the tables and the rest is history...
On the infeed table there are five twiddly bits.
1) underneath the infeed table is a black knob that locks down onto the screw thread used to adjust the height of the table during operation. Keep this slackened off while setting up.
2) ignore the black knob on the end of the screw thread mentioned in (1)
3) then you have another locking mechanism. I never really worked out quite what this does but while you are adjusting things slacken it off as well.
4 and 5) these are the boys. basically you need an allen key that fits the allen key and a spanner for the nut. When you loosen these the whole thing goes floppy as they keep it keyed in firmly to the main key ways that the infeed slides up and down on. (mechanical engineers and purists will have to put up with my technical terms
Wind the infeed up so it is on zero, put your level from the outfeed table across to the infeed table. A long level is needed ..ideally one that spans the entire lenght of both in/outfeed. make sure you're not touching the blades (you shouldn't be but if you are crank the infeed up a little higher.)
NB any correspondence between the infeed scale and 'true' measurements is purely coincidental...but in reality is pretty close (at least on mine).
Now start tweaking the allen key/nuts. Your mission, should you wish to accept this, is to tweak these so that you have a level table and also one that does not bind on the key rails as you adjust its height.
When it's all level and tickkety boo, tighten off the nuts and re-check. then loosen the nuts and reset it a bit more as sods law says it moves slightly as you tighten up the nuts and so you'll need to compensate a little on the allen key.
That worked for me.
in operation I loosen the knob in (1) and (3), adjust the height of the table and then tighten them up to lock the table down.
Hope that helps
Forget what you heard about shimming etc as I've never found out how to take the table apart to do it.
Roger
