Are these likely to be pony?
marcros
11 Feb 2011
Leeds
I doubt that they will be any better than any other cheap blade. The main difference is the amount of carbide, and on these it is probably not worth getting them sharpened. If you buy a decent blade, it will cost you more, but you can sharpen them numerous times at £5 a time (it is a while since I had one done). It works out cheaper in the long run.
I would go for a decent quality single blade over a pack of three. Freud, cutting solutions, wealdon etc.
MikeJhn
Grunkel
2 Sep 2014
Kent
The continuing problem is that until you use a decent blade you don't realise how bad the one you have is.
+1 for Freud
