I finally concluded with the underwriters today, and officially own the salvage of the saw that they were insuring on behalf of the couriers.... : /
It would have been a nice saw - 1ph in reasonable condition, with factory dust extraction motor hood etc but I think someone drove into it with a forklift, and bent the fence bars, and cracked up the fence casting and another part .
Anyway, I've purchased the salvage, and, worst case, will buy a cheap 3ph unit and make a hybrid from the two.
It would be wise for me to properly assess this one in the mean time, but at present I'm feeling a bit foolish in that it's not even clear to me the best way to get the table off.
Do you separate the lower, pressed steel section from the upper cast, and go about it that way, or is it best to remove the blade and stick your hands in that way?
The saw is in an awkward access space at present where I "shoved" it whilst the uncertainty of if it was going to be accquired by the underwriters was resolved, but I hope to get it moved to a more open space at the weekend.
I'll see if I can't add some photos then too, but it looks much the same as any other AGS10 that someone has driven into with a forklift.... : (
