MauriceD
I have recently bought a new Axminster Trade Series AWFS 18 scroll saw and I cannot understand why it is so slow to cut out exterior shaped animals in pine.
I also bought the “Scroll Saw Workbook” by John A. Nelson and I am trying to follow the exercises.
Today I took nearly an hour to cut out a cat in 20mm pine. (3/4 X 4 ½ X 5 ½) using a new number 5 skip-tooth blade (pinless).
I cut a piece of pine, covered it with the modern performance masking tape ( the one that is supposed to stop paint creeping under the tape), glued the pattern on top of this tape with Bostik Fast-Tak repositionable glue, and set to work.
The best way to explain the situation is that when you look at a clock you know the hands are moving but you cannot see the movement as it is so slow. Cutting out the cat was just like this.
I varied the speed between 1200 and 1400 but it did not appear to make much difference.
If it takes this amount of time for pine I don’t think I will be trying anything harder for some time.
From what I have said above does anybody see that I am doing anything wrong?
