Not my experience. Nor the experience of the generations of woodworkers whose livelihoods used to depend on these blades, or they wouldn't be so commonplace; they didn't feel the need to swap them.yetloh":3c6aoxer said:Mr G Rimsdale":3c6aoxer said:Personally I wouldn't bother changing any blades until they are worn out, which for most people will take a lifetime or more.
I've only ever needed to change one (on a block plane).
ceers
Jacob
Surpised this has gone unchallenged. In my experience most standard Stanley and Record blades are rubbish - rubbish, that is, if you want a really good edge that will last any time at all..
Mr G Rimsdale":27u9767j said:For me a little and often with average "quality" (whatever that means) thin steel is preferable (and sharper more of the time} than a less frequent and more difficult sharpening of say thick A2 steel.
Racers":2shxmvu3 said:Hi,
Modern blades are rubbish, but the old laminated or Crucible steel Record blades are good, and my homemade 3mm O1 steel ones are excellent.
Hmm. Right. So there is no point in paying more for mega metal blades - just as I thought!bugbear":20xsa257 said:Mr G Rimsdale":20xsa257 said:For me a little and often with average "quality" (whatever that means) thin steel is preferable (and sharper more of the time} than a less frequent and more difficult sharpening of say thick A2 steel.
If both types of blade degrade gradually from "just sharpened" to "needs sharpening", the sharpness graphs are the same shape (just different lengths on the time axis), and thus the proportion of the time spent in the "sharper" state are identical.
If that's too abstract, we can do numbers:
Assume we have "mega-metal" which holds an edge 10 times longer than "cheese".
If it takes 100 minutes of use to degrade, it will spend 10 minutes at "super sharp" (defined as 90% of "just sharpened").
The "cheese" (in this example) needs sharpening every 10 minutes. It will spend 1 minute at "super sharp" during this 10 minutes.
It will do this 10 times. Thus, in 100 minutes of use it will be "super sharp" for 10 minutes, just like the "mega metal".
(yes, I rigged the number to make the example easy to follow).
Result: both blades are "super sharp" for the same amount (and proportion) of time.
BugBear
Fashions come and fashions go!matthewwh":3q59nxmo said:..
I'm thinking about stocking good quality thin plane irons for this very reason - no mouth or yoke issues and you still get the vast majority of the improvement that you would by fitting a thick blade and properly designed cap iron...
matthewwh":z7ne80s1 said:£89.95 for a 2"
or £94.20 for a 2-3/8"
:shock:
Having no backlash at all is even more annoying. You need a bit of slack so that you can feel the adjuster taking it up as you move the blade in or out. Feedback in fact. With no backlash you can't quite tell what is happening.ali27":3qnue5jo said:..
Matthew thanks for responding on the backlash
thing. Yes I knew about what you described to me.
I just find it annoying the backlash...
Mr G Rimsdale":18c6co5m said:Hmm. Right. So there is no point in paying more for mega metal blades - just as I thought!bugbear":18c6co5m said:Mr G Rimsdale":18c6co5m said:For me a little and often with average "quality" (whatever that means) thin steel is preferable (and sharper more of the time} than a less frequent and more difficult sharpening of say thick A2 steel.
BugBear
Take into account that they are also thicker and hence more metal has to be removed for the same degree of sharpening then they look even more pointless. You missed that detail BB, otherwise you put it very well.
Yes. The cap iron should change over with no modification required. There seems to be some variance in Stanley planes over the years that can cause problems but generally it's only if you put a thicker iron in that there are problems.ali27":2ecrr1z2 said:Would replacing the stanley cap irons with Clifton
cap irons be ok without changing the yoke?
I believe stiffness is more important at the cutting edge, but the greater the mass, even further from the cutting edge, the less likely the iron will chatter.ali27":2ecrr1z2 said:Is it important that the whole blade is stiff or
just the cutting edge?
The slot in a Clifton cap-iron is about the same size as the slot in a Stanley/record so there should be about the same amount of backlash. I can't speak for the QS cap-irons.ali27":2ecrr1z2 said:Would replacing the stanley cap iron with a clifton
or QS cap iron increase/decrease backlash?
jimi43":2sovama3 said:Eric The Viking":2sovama3 said:I've got a Japanese laminated blade from Axminster in my #5. I really like it, but I doubt it's better than an Isles one.
I am itching to get one of those...but they were out of stock when I went to Sittingbourne....
Are they really good?
Jim
