Sorry if this is a bit of a random question.
I own a waterrower, a kind of rowing machine which uses a paddle in a water tank to create resistance.
The water tank started leaking today, after many years of usage.
It is basically made up of two halves which lock together. The junction between them is around 1mm wide and would need to be filled with a sealant/adhesive.
They sell a specific two parts adhesive but unfortunately all retailers I could find are out of stock and it would take 6 weeks at least to get hold of one.
So I am looking for a suitable alternative.
As you can see from the pictures above, the applicator is quite thin and the glue is not very viscous probably, given it needs to seep into the 1mm space between the inner and outer lips of the two halves.
Curing time of the kit is 4 hours, if that matters.
As I understand it, any alternative would need to be:
- Water proof and resistant to chlorine (low concentration)
- An adhesive, not just a sealer
- Vibrations resistant to some extent
- Reasonably easy to remove by scraping and rubbing with alcohol
- If possible, clear in color
- Thin enough to seep into that tiny space
I was thinking of something like Loctite PL Marine Fast Cure Adhesive.
Googling, I found a suggestion that "clear industrial silicone (Not acrylic)" should work, but I ma not quite sure frankly.
Everything I could find seem silicon based, in one part with no mixing required, such as Cromwell Tools - Experts in Hand Tools, Power Tools and PPE
Not sure if anybody here on the forum could point me in the right direction, based on on the above?
Thanks for any advice!
![2021-05-16_22h13_47.png 2021-05-16_22h13_47.png](https://cdn.imagearchive.com/ukworkshop/data/attach/91/91709-2021-05-16-22h13-47.png)
![2021-05-16_22h14_17.png 2021-05-16_22h14_17.png](https://cdn.imagearchive.com/ukworkshop/data/attach/91/91710-2021-05-16-22h14-17.png)
![2021-05-16_22h06_38.png 2021-05-16_22h06_38.png](https://cdn.imagearchive.com/ukworkshop/data/attach/91/91711-2021-05-16-22h06-38.png)
