custard
I've got a splayed leg trestle frame to make which will support a slab top. Here's the question, the legs are splayed in both directions by 1:10, which I calculate to be about 5.7 degrees. If the mitre saw is set so it's 5.7 degrees off from vertical, and 5.7 degrees off from being perpendicular to the fence, will that give me the correct angle for crosscutting the legs? I appreciate the legs are all "handed" so I'd have to reset the saw t'other way around for the next leg, but I want to check there's no weird geometry issue like azimuth error that'll catch me out?
By the way, I've made a 1:10 MDF master template so I can repeatedly re-set a sliding bevel to a consistent angle, so that's not the issue, I'm not really bothered if it's 5.6 degrees or 5.8 degrees as long as it's consistent. The question is, when you compound the angle is there some other factor that needs to be allowed for, or is it all as straightforward as I think it is?
Thanks.
Thanks.
