9mm groover router cutter?
I do mostly use Wealden tools cutter, but they don't do a 9mm, only 9.5mm.
eribaMotters, do you use the 9.5mm? I considered this but think it would be a slightly sloppy fit.
Simon, that maybe my solution ;-)
It is the 9.5mm that I use. I have found that this is the correct size for 9mm mdf panels. When I bought a wobble saw for my spindle I originally set it to 9mm, but found the fit was tight and increased it to nearer the 9.5mm of the Wealden groover.
Colin
